Cooler differences
Solved by For Science!,
12 minutes ago, Luisa said:PRO one right? Thanks
H115i pro - Gen 5 pump, Slightly more static pressure optimized fans, "true rgb" (fancy changing options)
H115i - Gen 4 pump, not true RGB (select one color and it just stays that color)
Gen 4 pumps are actually slightly quieter and better performing in terms of flow. If you don't care about RGB, want a slightly quieter pump and were going to change the fans anyway, the H115i is not a bad choice.
