Bent audio capacitor
Go to solution Solved by Opencircuit74,
You'll be fine, the connectors are still in place and that's all that really matters.
Hi,
It was pointed out to me that the bottom left hand capacitor in the group of four is bent. I tried to push it down slightly which has given it a tiny bit of play. It only wiggles slightly if put under pressure.
It's an audio cap and it's away from the rest of the motherboard.
My question, is it still safe to use?
Appreciate opinions on this.
https://linustechtips.com/topic/993719-bent-audio-capacitor/
 CPU: I9-7900X RAM: 64GB (16X4) DDR4-2933 GPU: RTX 3080 MOBO: ASUS X299 Deluxe PSU: Corsair RM850 SSD: ADATA XPG SX8200 PRO 1TB HDD: Seagate Barracuda 2TB Case: Corsair iCUE 465X Cooler: Corsair 280 AIO
https://linustechtips.com/topic/993719-bent-audio-capacitor/#findComment-11955044
  • 7 months later...
