Hello thank you for taking time out of your day to help me, okay first thing when i try to use my headset microphone it makes a buzzing sound and when i go to plug it in to my headphones the buzzing is louder, my xlr microphone makes a buzzing sound when i hold it to move it closer to me, please help me.
https://linustechtips.com/topic/993685-help-please/
It sounds like you're having what's called a "ground-loop" issue.  Could you give us more details of your setup?  There may be some changes you can make to alleviate it.  Makes and models, interfaces and how you're getting power to everything are the details that matter most.
https://linustechtips.com/topic/993685-help-please/#findComment-11954807
Just now, ShredBird said:
It sounds like you're having what's called a "ground-loop" issue.  Could you give us more details of your setup, there may be some changes you can make to alleviate it.  Makes and models, interfaces and how you're getting power to everything are the details that matter most.
i have a corsair hs60 headset with the 7.1 usb
let me know it you need more.
https://linustechtips.com/topic/993685-help-please/#findComment-11954814
Sometimes, noise on your 5V power line can bleed into your recording and playback circuits.  The cleanest source of 5V power would likely be the rear I/O panel on your motherboard as opposed to the front.  Try a port on the back and see if it makes a difference.
Another tip is to use the least amount of microphone gain you can get away with.  On a level meter you want to stay under 0 dB mark while speaking normally, the more gain you apply the more you are also amplifying the noise.  Check your gain settings and set them to the lowest you can get away with.
What about your XLR microphone?  Is that plugged into an XLR interface?  Is that powered by USB as well?
https://linustechtips.com/topic/993685-help-please/#findComment-11954876
the xlr microphone is plug in to a neewer 48v phantom power supply and it is powered my ac/dc power cable
https://linustechtips.com/topic/993685-help-please/#findComment-11954889
2 minutes ago, ShredBird said:
Could be a ground loop issue.  You may look into these types of products to alleviate some hissing:
https://www.bhphotovideo.com/c/buy/Hum-Eliminators/ci/15139/N/3992462126
how would i plug it in to my pc? and how could i fix my usb headset
https://linustechtips.com/topic/993685-help-please/#findComment-11954913
I would try the things I mentioned for the USB headset, changing ports and adjusting gain.  You might try something like this:
https://www.bhphotovideo.com/c/product/365781-REG/Ebtech_HUM_X_Hum_X_Ground_Loop.html
Just plug your powerstrip into one of these and it *might* help.  I would see if you can get this from somewhere that has a good return policy.
https://linustechtips.com/topic/993685-help-please/#findComment-11954937
thank you
https://linustechtips.com/topic/993685-help-please/#findComment-11954948
