hi im having problem with my s7 edges battery, will replacing it fix the problems, it is draining really fast
Current PC and Peripherals
CPU: i7 6700
CPU cooler: Cryorig H7
GPU: Evga RTX 2070
Memory: 16gb Corsair RGB
HDD: 1tb WD blue
SSD: 120gb Kingston
Headphones: Hyper x Cloud
Keyboard: Logitech g810
Mouse: Logitech g502
Monitor: Aoc 60hz
Other tech I own
iPhone 8
Edifier Prisma
Amazon echo dot
Apple Airpods
Go Pro Hero 7
https://linustechtips.com/topic/993607-s7-edge-battery/
If it is old, then yes, replacing can help.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/993607-s7-edge-battery/#findComment-11954123
ok thanks
CPU: i7 6700
GPU: Evga RTX 2070
HDD: 1tb WD blue
SSD: 120gb Kingston
Monitor: Aoc 60hz
Other tech I own
iPhone 8
Edifier Prisma
Amazon echo dot
Apple Airpods
Go Pro Hero 7
https://linustechtips.com/topic/993607-s7-edge-battery/#findComment-11954127
6 minutes ago, VenomZ_ said:
Did you root it? if so say goodbye to your battery
no i didnt im not stupid
CPU: i7 6700
GPU: Evga RTX 2070
HDD: 1tb WD blue
SSD: 120gb Kingston
Monitor: Aoc 60hz
Other tech I own
iPhone 8
Edifier Prisma
Amazon echo dot
Apple Airpods
Go Pro Hero 7
https://linustechtips.com/topic/993607-s7-edge-battery/#findComment-11954166
Rooting does not make the phone consume more battery. In fact it could be the opposite - you can save battery, if certain changes are applied, which are not possible without root.
https://linustechtips.com/topic/993607-s7-edge-battery/#findComment-11954182
na theres some kind of lock samsung has that fucks your phone if you root it
https://linustechtips.com/topic/993607-s7-edge-battery/#findComment-11954363
1 minute ago, VenomZ_ said:
sorry I thought you were because that reply implies that you are.
what ever u say bud
CPU: i7 6700
GPU: Evga RTX 2070
HDD: 1tb WD blue
SSD: 120gb Kingston
Monitor: Aoc 60hz
Other tech I own
iPhone 8
Edifier Prisma
Amazon echo dot
Apple Airpods
Go Pro Hero 7
https://linustechtips.com/topic/993607-s7-edge-battery/#findComment-11954373
