 So I am planning on buying a pre-built pc, cause i do not know how to build one.
I am playing on 1080 60Hz monitor so i know these rigs are pretty op but i want them to last several years from now on.
I found 2 pre-built pc's which I found to be ok.Below I will show you the specs of each pc:
1,650$ PC:
Ryzen 7 1800x 3,6ghz
Geforce RTX 2070 OC
32 GB DDR4 3000 Mhz Ram
1xNMVE SSD 128 GB
1x 2TB HDD
I don't know the motherboard but it has these ports
1x DVI
1x HDMI
1x PS/2 Mouse-Tastatura
1x RJ-45 LAN
4x USB 2.0
4x USB 3.0
And the PS has 650 W
1,750$ PC:
I7 7700
16 GB DDR4 2400 Mhz
Gtx 1080ti
256 GB SSD+2 TB SSD
I don't know the motherboard on this too
And it has a 750W PS
So please tell me what do you think about these builds.I also would love to hear some tips from you guys!Thanks!
Btw sry for my english but i am from Romania.
https://linustechtips.com/topic/993560-1650-pc-vs-1750-pc-help/
Why both using last gen CPU?
https://linustechtips.com/topic/993560-1650-pc-vs-1750-pc-help/#findComment-11953773
Assuming your seller is using the cheapest parts available these are what i can assume your are getting
PCPartPicker part list: https://pcpartpicker.com/list/wyFMD2
Price breakdown by merchant: https://pcpartpicker.com/list/wyFMD2/by_merchant/
CPU: AMD - Ryzen 7 1800X 3.6 GHz 8-Core Processor  ($244.70 @ OutletPC)
CPU Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.89 @ OutletPC)
Motherboard: MSI - X370 GAMING PLUS ATX AM4 Motherboard  ($79.47 @ B&H)
Memory: G.Skill - Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  ($229.99 @ Newegg)
Storage: ADATA - XPG SX6000 128 GB M.2-2280 Solid State Drive  ($37.89 @ OutletPC)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($58.89 @ OutletPC)
Video Card: Gigabyte - GeForce RTX 2070 8 GB GAMING OC Video Card  ($549.99 @ Newegg)
Case: DIYPC - P48-W ATX Mid Tower Case  ($29.96 @ Newegg)
Power Supply: Rosewill - Capstone 650 W 80+ Gold Certified Semi-Modular ATX Power Supply  ($44.99 @ Newegg)
Total: $1300.77
Generated by PCPartPicker 2018-11-11 10:08 EST-0500
PCPartPicker part list: https://pcpartpicker.com/list/c7Ck7W
Price breakdown by merchant: https://pcpartpicker.com/list/c7Ck7W/by_merchant/
CPU: Intel - Core i7-7700 3.6 GHz Quad-Core Processor  ($307.75 @ OutletPC)
Motherboard: MSI - B250M PRO-VD Micro ATX LGA1151 Motherboard  ($64.89 @ OutletPC)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-2400 Memory  ($104.99 @ Amazon)
Storage: ADATA - XPG SX850 256 GB 2.5" Solid State Drive  ($44.99 @ Amazon)
Video Card: Zotac - GeForce GTX 1080 Ti 11 GB Mini Video Card  ($704.98 @ Newegg)
Case: Corsair - SPEC-02 ATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply: Rosewill - Capstone 750 W 80+ Gold Certified Semi-Modular ATX Power Supply  ($49.99 @ Newegg)
Total: $1391.36
Generated by PCPartPicker 2018-11-11 10:07 EST-0500
Bolivia.
https://linustechtips.com/topic/993560-1650-pc-vs-1750-pc-help/#findComment-11953866
Total: $1300.77
Total: $1391.36
I forgot to mention that the first build has liquid cooling for the amd cpu. If you wanted i could give you the link of the first build.In case you want it here it is:http://m.cel.ro/calculatoare-desktop/diaxxa-evo-v3-ryzen-7-1800x-3.60ghz-2tbplus_128gb-nvme-32gb-ddr4-geforce-rtx-2070-8gb-gddr6-pMCIzNzYsMg-l/
https://linustechtips.com/topic/993560-1650-pc-vs-1750-pc-help/#findComment-11953900
Avoid this like the plague. That is a custom loop. If you are not comfortable enough to build your own PC you aren't qualified to drain, clean, and fill that loop in two years...
PC building is easy now. It's legos for adults. Do you have Amazon where you live? Don't waste money on a pre-built.
Rest In Peace my old signature...                  September 11th 2018 ~ December 26th 2018
https://linustechtips.com/topic/993560-1650-pc-vs-1750-pc-help/#findComment-11956026
I can buy from Amazon but the transport fee is around 700 bucks
https://linustechtips.com/topic/993560-1650-pc-vs-1750-pc-help/#findComment-11957054
Got any local technology shops?
https://linustechtips.com/topic/993560-1650-pc-vs-1750-pc-help/#findComment-11958856
