White blades with a black frame, or the blades themselves are white and black?
Fans that have color variations by blade are practically nonexistent.
https://linustechtips.com/topic/993018-radiator-fans/#findComment-11948873
Fractal Venturi HP14?
Desktop benching:
https://linustechtips.com/topic/993018-radiator-fans/#findComment-11948875
I kinda mean something like this200
https://linustechtips.com/topic/993018-radiator-fans/#findComment-11948901
then just get that thing? Otherwise the Corsair ML140 RGB will do, just don't plug in the RGB cable and it will stay white.
Desktop benching:
https://linustechtips.com/topic/993018-radiator-fans/#findComment-11948915
1 minute ago, Txe said:
But would it do good for radiators?
unless it's very thick (thicker than those on AIOs) they are fine.
If you don't mind the small coloured ring on the the fan hub, the Cryorig QF140 is also a viable option.
Desktop benching:
https://linustechtips.com/topic/993018-radiator-fans/#findComment-11948938
Im getting the Kraken x62 from NZXT is it a thick radiator?
https://linustechtips.com/topic/993018-radiator-fans/#findComment-11948943
Phanteks PH-F120MP
Have 6 of them. Work pretty well on my high fpi rad. Quiet even at higher rpms. I don't like the looks myself but they perform and match what you are looking for.
https://linustechtips.com/topic/993018-radiator-fans/#findComment-11949072
No, just average thickness
Desktop benching:
https://linustechtips.com/topic/993018-radiator-fans/#findComment-11949331
Take a look at these EK-Vardar EVO 140S. They're pwm controlled and Im using a similar model that works great.
RIG   CPU / AMD - Ryzen 7 2700X, Motherboard / ASUS - ROG Crosshair VII Hero (Wi-Fi), RAM / Corsair - Vengeance RGB Pro 16 GB (2 x 8 GB), GPU / 2x EVGA - GeForce GTX 1080 Ti FTW3 GAMING iCX, Case / Thermaltake - View 71, Storage / Samsung - 970 Evo 1 TB M.2 SSD, 2x Crucial - MX500 1 TB SSD, PSU / Corsair - HX1200i, Display(s) / ASUS - ROG Swift PG27VQ, Cooling / 2x EK - CoolStream PE 360, 6x EK-Furious Vardar EVO 120, 3x Thermaltake - 140mm Riing RGB Fan, EK - FB ASUS C6H RGB Monoblock, 2x EK - FC1080 GTX Ti FTW3 RGB Nickel, Aquacomputer - kryo M.2 PCIe 3.0 x4 Adapter & waterblock, Keyboard / ASUS - ROG Strix Flare (Cherry MX Red), Mouse / Logitech - G500s, Sound / Sennheiser - Game Zero Special Edition
https://linustechtips.com/topic/993018-radiator-fans/#findComment-11951216
I also have a variety of the Fractal fans,  they are all 'high pressure'  and most of the Phanteks ones were too.
Also not Arctic-silver.  But ARCTIC  the one that makes MX-4/other stuff  also sell a black/white Fan.   I only have the 80mm (2x5pack)   but they are pretty boss little things, almost as good as Noctua-80mm   but i got a 5-pack of  for  66% the cost of a single fan  so it was a no brainer to buy them
https://linustechtips.com/topic/993018-radiator-fans/#findComment-11953956
