First Time DIY liquid cooling
Solved by PrimeSonic,
TL:DR - The impact that loop order has on temperatures is basically a rounding error.
Don't worry about loop order.
My advice from personal experience: Spend more time making sure your loop is easy to fill and drain, before you worry about inconsequential things like loop order.
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases6 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning19
play_circle_filled
Latest From ShortCircuit:
