Notebook serious wireless problems!
First of all, i'm not considerning myself a noob! A know a lot of tech stuff, i can diagnose pretty much any hardware and software issue. One thing I don't know: why is the wireless adapter detected and off and the button to enable it in mobility center is unclickable? The real problem is that this is happening all the time, I just gave up on workloading for the 4th laptop! I's sure i instaled the proper drivers for wlan card! I even restored one notebook using prebuilded recovery partition and still same thing! Please help me out guys! Sorry for my English!
FX8320 4.2Ghz@1.280v& 4.5 Ghz Turbo@1.312v Thermalright HR-02/w TY-147 140MM+Arctic Cooling 120MMVRM cooled by AMD Stock Cooler Fan 70MM 0-7200 RPM PWM controlled via SpeedfanGigabyte GA990XA-UD3Gigabyte HD 7970 SOC@R9 280X120GiBee Kingston HyperX 3K2TB Toshiba DT01ACA2001TB WD GreenZalman Z11+Enermax 140MM TB Apollish RED+2X Deepcool 120MM and stock fans running @5VSingle Channel Patriot 8GB (1333MHZ)+Dual Channel 4GB&2GB Kingston NANO Gaming(1600MHZ CL9)=14GB 1,600 Jigahurtz 10-10-9-29 CR1@1.28VSirtec High Power 500WASUS Xonar DG, Logitech F510Sony MDR-XD200Edifier X220 + Edifier 3200A4Tech XL-747H 3600dpiA4Tech X7-200MPdecent membrane keyboardPhilips 236V3LSB 23" 1080p@71Hz .
Sorry for my English....
https://linustechtips.com/topic/9921-notebook-serious-wireless-problems/
On my old laptop when you let windows manage the wireless card the program used, in my case I believe was called Proset or something, it would disable and be all greyed out. Not sure how much this helps.
Is this the real life? Or is this just fantasy?
thanks guys, but still nothing!
