Freesync not working
Solved by MkaiL,
1 minute ago, Firas64 said:so plqying zith freesync in 75fps is better then nonsync in 300fps and how to limit my fps to 75fps ?
It's a choice you have to make for yourself. Some people claim, even though their screen is 60 or 75hz, that higher ingame fps still makes it look smoother but like you have found out, it can cause screen tearing. I see a lot of people that use freesync avoid vsync and leave it off, instead they use a frame limiter like amd's FRTC. I would just play around with different settings and see what works best for you.
