19 minutes ago, LevWalker said:
I want to have multi use tickets barcode or QR or something else Doesent matter. But I would like to be able to scan something 5 times or 10etc and after that it shows that it’s not valid. Thanks in advance!
You need to build something that keeps track of which code was used and how many times it was used.
That's the gist of the solution, I'm not sure what you were planning on doing to implement it though.
https://linustechtips.com/topic/991747-ticketing-solution/#findComment-11936896
