Network at Work wont Identify...HALP
For some reason at home I can connect just fine wirelessly, Wired via Ethernet, Wired via Ethernet->TypeC(Even tho acer says it isnt supposed to)
However when I go into work the network wont Identify and it doesnt give me the option to change it to a private network when plugged in via Ethernet or TypeC. Wireless works fine but its the Guest WiFi network.
It worked at one point and suddenly just stopped.
I have done everything I could find/googled
Resetting adapters
Pinging fails with 100% packet loss
Tried Network Reset
Disabled Fast Startup
Updated Drivers/Uninstalled and Reinstalled
IP Configuration is set to Auto
Rebooted Modem, Router, Network Switches
Any help would be greatful!
https://linustechtips.com/topic/991665-network-at-work-wont-identifyhalp/
