Threadripper Build Advice
Go to solution Solved by lmeneses,
23 minutes ago, Evni said:
Well I ended up with a cool looking X399 board so I had to do something with it. And its been like 3 months since I built my main PC so obviously I need a brand new one.
He does have a point, guys
Finalizing the parts list for my next build, wondering if anyone sees any issues? Everything will be cooled under a custom loop.
Only parts I don't have atm are the CPU and memory, plus some watercooling stuff. Most of the parts were chosen just because I had them on hand. I don't have the 980 Tis yet but I've arranged a trade for them and they include full cover waterblocks. If theres an issue with that, let me know. Thanks.
https://www.reddit.com/user/scarlet_shade/
Main PC: (custom waterloop)
Threadripper 1950X @ stock
8x8(64GB) Corsair Vengeance RGB Pro @ 3000mhz
Asus Prime X399-A
2x EVGA 980 Ti Classified w/ EK Waterblocks (SLI)
Corsair AX1200 w/ White Cablemod
512GB Samsung 850 Pro
512GB Intel 600p M.2 NVME
NZXT H700i White
'Media' PC:
i5 8600k @ 4.9GHz
Corsair H80i 120mm AIO
16GB TridentZ @ 4133mhz
Asus z370-i Strix ITX
EVGA GTX 1070 Ti FTW2
Corsair SF600 SFX PSU
256GB SL308 SSD
500GB WD Blue SSD
Thermaltake Core V1 ITX Case
https://linustechtips.com/topic/991394-threadripper-build-advice/
what will you do with it?
Desktop benching:
Nothing really. Probably just watch anime.
Asus Prime X399-A
NZXT H700i White
'Media' PC:
i5 8600k @ 4.9GHz
256GB SL308 SSD
500GB WD Blue SSD
In that case, why don't you get the 1950X?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
imo 1950x with half the RAM is better. You still get quad channel memory that way
Desktop benching:
The 1950X is more expensive though and I doubt I'd notice a difference. I'd rather fill up all the RAM slots.
Asus Prime X399-A
NZXT H700i White
'Media' PC:
i5 8600k @ 4.9GHz
256GB SL308 SSD
500GB WD Blue SSD
why get 16 cores for watchng anime tough?
hell, why even get 12?
anyway, this build should be compatible, so it should be a smooth build.
HelplessOffensiveIndianpalmsquirrel-size
counting boxes in Task Manager :P
Also if upping core count isnt noticeable, then so is having more RAM.
Desktop benching:
When buying memory for a quad channel capable cpu one should opt for 4 or 8 module kits. Buying multiple dual channel kits does not guaranty quad channel operation as kits may not be electrically compatible.
Asus Prime X399-A
NZXT H700i White
'Media' PC:
i5 8600k @ 4.9GHz
256GB SL308 SSD
500GB WD Blue SSD
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
