Laptop hard disk replacement for newbie
Solved by SuperCloneRanger,
Your laptop should be able to take any standard 2.5" hard drive, there's a version of it that came with a 1TB SSHD. I did look at the spec on the 2TB firecuda and it does not draw more power than any other drive. I'm also positive the bios can 'handle it'. I read the post on the lenovo forums and i'm pretty sure the guy messed up the formatting when he tried to clone his old drive. Just do a clean install of windows and you'll be fine.
windows media creation tool:
