I've posted a few topics on here about my issue and I've tried many solutions. I built my first PC and have it up and working for the most part. The problem is that I keep getting a BSOD error "CLOCK_WATCHDOG_TIMEOUT" and I have no clue at all how to fix it. I've reinstalled Windows twice from the installation disc and once from the Media Creation Tool via USB. I've updated all drivers, have my BIOS settings set to auto, and have the newest BIOS update to support my CPU. Here's a PCPP list if you need it:
https://pcpartpicker.com/list/tXynMZ
I need to find a way to fix this issue. Another problem is that when I try to update Windows I get a bunch of errors beside the update in the settings and it freezes while downloading and I have to restart it.
https://linustechtips.com/topic/990712-bsod-clock_watchdog_timeout-issue/
6 minutes ago, That_PC_Kid said:
No
Try resetting your CMOS, then check in BIOS to make sure your RAM is running at 2133MHz and your CPU clock speed is set to auto. Boot it back up afterwards and see how it does. That BSOD is usually related to a bad overclock, either CPU or RAM.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
