2 minutes ago, Banshee_Trey said:
What power supply? Stock RAM settings or did you use the XMP settings? What's your CPU/GPU temps?
https://linustechtips.com/topic/990619-help-needed/#findComment-11926732
I’ve tried tweaking settings but none worked so now it’s all back to default. I made the gpu’s Fans stay on a higher than needed level so it’s temps stayed around 42-52°c. I don’t really know any programs to get cpu temp..
https://linustechtips.com/topic/990619-help-needed/#findComment-11928783
If you haven't already reinstalled windows try going into MSI afterburner or something and set the GPU's power target to 50%
Does it crash when you try to run just cinebench?
https://linustechtips.com/topic/990619-help-needed/#findComment-11929464
I do not have cinebench but I can try doing the gpu power target.
https://linustechtips.com/topic/990619-help-needed/#findComment-11930131
Cinebench is free to download and use, if it doesn't crash from CPU stress only then the issue is between the GPU and power supply.
https://linustechtips.com/topic/990619-help-needed/#findComment-11930167
19 minutes ago, Banshee_Trey said:
It can run through cinebench just fine.. gpu and cpu.
Most likely the issue is with the GPU then
For some reason it could be the motherboard and/or the PCI-e slot.
Or the power supply
But most likely the GPU just try exchanging it or returning it or something.
https://linustechtips.com/topic/990619-help-needed/#findComment-11930327
Or the power supply
Ive tried all 3 PCI Slots, still same issue... I am going to look into getting in a new PSU
https://linustechtips.com/topic/990619-help-needed/#findComment-11930334
You should find another system to test the GPU in before you go off buying a new PSU
If your current PSU can handle a heavy load on your CPU it's probably not the power supply.
https://linustechtips.com/topic/990619-help-needed/#findComment-11930338
