I am going to be replacing my Thermaltake smart series 650w Non modular psu to a 750w evga supernova g3 and was just wondering of there would be anything that would be incompatible.
PC Specs:
CPU:i7 6700K
MOTHERBOARD: ASUS Z170-A\
RAM:G.skill aegis 16GB DDR4 2400MHZ
CASE: Corsair 570X RGB
COOLER: NZXT Kraken X52
STORAGE: 3tb hard drive, 120gb ssd.
GPU: GTX 1080 ASUS STRIX
OTHER: 6 120mm fans, Lighting node pro from corsair.
Please tell me if there are any incompatibilities. I already checked PC Partpicker but I didn't enter in the Node pro and the fans plus its better if you guys tell me. Thanks!
https://linustechtips.com/topic/990242-i-am-upgrading-need-some-help/
59 minutes ago, seon123 said:
Why would you ever get the G3 750W for that system?
Compatible, yes. But the G3 is among the loudest PSUs on the market, and it has issues with its protections
So what PSU should I get?
Depends on what's available, and the pricing.
Whisper M 450W, Straight Power 11 450W, RM550x 2018 or RM550x. If none of those are available, Focus Plus Gold 550W, CM V550, GX-F 550W, Focus 450W, Earthwatts Gold Pro 550W, G2 550W or TX550M.
The system will draw about 300W under load, so you don't need anywhere near a 750W PSU.
Wow I didn't know that ok thanks
