pci problem
Go to solution Solved by Electronics Wizardy,
1 minute ago, AHMED 111 said:
which one should i use for gpu and the other for extra sata ports
3 minutes ago, AHMED 111 said:
i use a optiplex 380
Looking at the board, there is a single pcie slot(the black one) the other slots are pci, not pcie. '
What sata card do you want? You probably need a pci card.
https://linustechtips.com/topic/990153-pci-problem/#findComment-11922890
