Best case for watercooling?
Go to solution Solved by Zyndo,
8 minutes ago, Noah0302 said:
Thanks for the reply! Those cases are already looking good.
I dont need a TG front panel, but the 360 is a must for me.
there are a metric boatload of cases with 360mm front mounts, but many only have 240/280 top mounts. So you can still very easily get a 360mm into a case, but it just won't be on the top. Something like the Corsair 500D or 460x/570x are things to look at.
Also, if you don't need a see through front panel, something like the Define R6 or S2 from Fractal Design are excellent 360mm top mounted cases.
Hi, I have good experience in building air cooled PCs but I never built a liquid cooled one.
So I need some help picking a case that does everything I want from it. I currently use the Coolermaster Masterbox 5, so something similair to that one would be great.
1- It has to fit a 3 120mm AIO block on top.
2- At least 3 in the front for air flow and one in the back.
3- Aura sync compatible.
4- Tempered glass side and front, so I can see the RGB fans.
5- Preferrably silent and not as loud as my current Masterbox 5.
And if you could suggest some good Aura sync AIO coolers (don't need RGB fans since I can replace them), that is able to cool my i7 8700k @5GHz it would be awesome!
Price sould not be an issue!
Also I found out about the ASUS Strix case and wondered if it would be worth waiting for the release, since I also thought about getting the ASUS ROG Ryujin 360 since Im a huge asus fan.
My Gaming PC:
Inno3D iChill Black - RTX 4080 - +500 Memory, undervolted Core, 2xCorsair QX120 (push) + 2xInno3D 120mm (pull)
AMD Ryzen 7 7800X3D - NZXT x72
G.SKILL Trident Z @6000MHz CL30 - 2x16GB
Asus Strix X670E-E Gaming
1x500GB Samsung 960 Pro (Windows 11 + 10)
1x2TB Kingston KC3000 (Games)
1x1TB WD Blue SN550 (Programs)
1x1TB Samsung 870 EVO (Programs)
Corsair RM-850X + native 12VHPWR-Cable
Lian Li O11 Vision
Alienware 360 HZ QD-OLED AW2725DF, MSI Optix MAG274QRFDE-QD, BenQ ZOWIE XL2720
Logitech G Pro Wireless Superlight 2
Wooting 60HE
Audeze LCD2-C + FiiO K3
Klipsch RP600-M + Klipsch R-120 SW
My Notebook:
MacBook Pro 16 M1 Pro - 16GB
Proxmox-Cluster:
  • Ryzen 9 3950X, Asus Strix X570E F-Gaming, 4x32GB3200MHz ECC, 2x 512GB NVMe ZFS-Mirror (Boot, Testing-VMs + TrueNAS L2ARC), 2x14TB ZFS-Mirror + 1x3TB (TrueNAS-VM), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
  • i7 8700k delidded undervolted, Gigabyte Z390 UD, 4x16GB 3200MHz, 2x 360GB HDD ZFS-Mirror (Boot), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
  • i5 4670, 3x4GB + 1x8GB 1600MHz, 2x 240GB HDD ZFS-Mirror (Boot), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
Proxmox-Backup-Server:
  • i5 4670, 4x4GB 1600MHz, 2x2TB ZFS-Mirror, 2,5G NIC
https://linustechtips.com/topic/989797-best-case-for-watercooling/
16 minutes ago, Noah0302 said:
Snip
Best watercooling case, on the market, with triple fan support and TG on front/side, would probably be this one: https://pcpartpicker.com/product/Hwkj4D/lian-li-pc-o11dx-atx-full-tower-case-pc-o11dx
Comes in black or white if need be.
Also this:
https://pcpartpicker.com/product/xFs8TW/anidees-ai-crystal-atx-mid-tower-case-ai-crystal
https://pcpartpicker.com/product/pBp323/thermaltake-view-31-tg-atx-mid-tower-case-ca-1h8-00m1wn-00
(Acrylic front panel) https://pcpartpicker.com/product/q4YLrH/thermaltake-view-22-tempered-glass-edition-atx-mid-tower-case-ca-1j3-00m1wn-00
those are the ones I could find anyway... there are likely more. Also, the list becomes MUCH longer if you're willing to not NEED a 360 on top, or if you're willing to give up a TG front panel requirement.
Also this:
My Gaming PC:
Lian Li O11 Vision
Wooting 60HE
My Notebook:
Proxmox-Cluster:
