specs gtx 1070  intel i7-8700k 16gb DDR4 corsair vengeance RAM
so i can run rust and ark smoothly (very good looking games) however after trying out minecraft again after years, it lags.... ALOT. i would appreciate any help i can get.
Pc
CPU: Intel i7-8700k
GPU: GTX 1070 Superclocked
Motherboard: MSI Z370 Gaming Plus
RAM: 16Gb Corsair Vengence DDR4
Cooler: Corsair h60 liquid cooler
HDD: 1TB
https://linustechtips.com/topic/989761-high-end-pc-not-running-minecraft/
I don't play Minecraft but, I know that you have to give it more RAM in the launcher.
It uses a very low amount by default.
Make sure to quote or tag people, so they get notified.
Minecraft has gotten worse over the years since Microsoft took over. If you are running modded MC through a program such as Technic Launcher, in the settings is the option to choose how much ram it can use. (Set to 1GB on default).
@SomeTeenThatLovesComputers i switched the amount of RAM usage to 6 and it still lags. it doesnt lag when i turn off Vsync but i kind of want it on so any other fixes?
Pc
CPU: Intel i7-8700k
HDD: 1TB
also a side note i am using nvdia geforce experiences optimal settings (Which are just max settings)
Pc
CPU: Intel i7-8700k
HDD: 1TB
