Case fans (Optimal Layout)
Go to solution Solved by Jurrunio,
I'd just say put Air Pressure in mounts with air filter, Airflow in those without.
So i have three fans to choose.
1. MasterFan 120 Air flow
2. MasterFan 120 Air Balance
3. MasterFan 120 Air Pressure
Ill be using the case: Corsair 460x
And ill will have the cpu rad: h60 (2018). ill be replacing all fans with a mixture of these (Asus aura) for rgb* purposes.
My question is which fans should i get and where. and also where should my rad go? im thinking either TOP Right, or Front pannel TOP.
https://linustechtips.com/topic/989600-case-fans-optimal-layout/
Desktop benching:
Just now, Vonix said:
So like airpressure for Top front and rad. and get 1 airflow for rear?
yup
Desktop benching:
20 minutes ago, Vonix said:
or like balance for rad. cause thats what coolermaster use on there rads
Cooler Master uses their Balance fans on their rads with less restrictive square fins. They're also higher rpm than their aftermarket RGB counterparts.
Most AIO's have rads with more restrictive fin arrays and perform better with Cooler Master's Pressure fans as opposed to Balance especially when comparing lower rpm aftermarket fans. The H60 2018 has a slightly looser 18 FPI compared to the original H60's 20 FPI but would probably still be better off with Pressure fans due to the lower rpm.
