So atm I have a 750Ti, Intel 1037u CPU and 8gb ram, I want to upgrade and I got recomended this:
build from someone on this site, the Ryzen 3 1200 is £76 for me, basically £77 but I seen a Ryzen 3 2200G for £89.99, with the CPU upgrades would it be worth to pay the little extra for the 2200G rather than the 1200? and also what performance increase would I be looking at for Fortnite, CS:GO and other demanding titles like that?
https://linustechtips.com/topic/989423-first-built-pc/
Consider getting a higher end processor and keep using the 750ti for a little while longer until you can afford a rx 570/80.
https://linustechtips.com/topic/989423-first-built-pc/#findComment-11915814
The main difference between the 2200G and the 1200 is that the 2200G has built in graphics. Since you already have a dedicated GPU on the list (the GTX 1050Ti), I don't see much of a reason to get the 2200G. Unless you want to get/have a FreeSync monitor and want to exploit the glitch where you run FreeSync with the Nvidia GPU
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/989423-first-built-pc/#findComment-11915822
I would do this, however my little cousin will be getting this current PC for his homework and slight gaming etc.
https://linustechtips.com/topic/989423-first-built-pc/#findComment-11915844
The 2200G also has a higher clock speed which would be beneficial to CS:GO (3.4 vs 3.7 GHz Turbo)
Current Build
Successful Builds
https://linustechtips.com/topic/989423-first-built-pc/#findComment-11915846
If you aren't going to get a FreeSync monitor, you have no reason to spend extra on a CPU with a feature you won't use.
*GPU Test Bench*
https://linustechtips.com/topic/989423-first-built-pc/#findComment-11915848
He'd probably be better off getting the 1200 for cheaper and putting a slight OC on it.
*GPU Test Bench*
https://linustechtips.com/topic/989423-first-built-pc/#findComment-11915850
Good point, however I'd have to look how to overclock etc.
Here is a new one I've found:
CPU: Ryzen 2300X 4.0GHz
GPU: RX 570 4GB
RAM: 8GB DDR4 2400MHz
Storage: 240GB SSD.
This is around £500 give or take, however I've heard good and bad things about the GPU.
https://linustechtips.com/topic/989423-first-built-pc/#findComment-11915947
GPU: RX 570 4GB
Storage: 240GB SSD.
Honestly, what you could do is just get the 2300x in the original build. The 1050Ti is better than an RX 570.
I would highly recommend you get an SSD as well, though if you can't afford it don't bother.
Edit: As long as you get a B350 board, OC will be fine. Ryzen Master makes OC easy (supposedly, though I can't figure it out, lol)
*GPU Test Bench*
https://linustechtips.com/topic/989423-first-built-pc/#findComment-11915966
