Wierd GPU Temperature during idle
Go to solution Solved by flibberdipper,
Semi-fanless operation card + load = funky behavior like this. Depending on what model 1060 you have, the cooler might just be too small to handle the increased clocks from Firefox using it for acceleration (or potentially even not enough case airflow). ?
During Idle, my gpu would be temps would go up to 58 degrees, fan kicks in and drop temps down to 51, then goes back up to 58 again. The process would repeat itself many times and would never stop. Is this normal?
*Firefox is running 6 tabs of LTT forum, hence the 44% ram usage
Edited by gabrielquek92
Included more information
https://linustechtips.com/topic/989382-wierd-gpu-temperature-during-idle/
Isn’t idling if you are using it. Make a better fan curve.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
It’s using the gpu. Use equals temps.
