Ubiquiti EdgeRouter X - One port not working at gigabit
snowfox99
So I've been using a Ubiquiti EdgeRouter X for my home network and it's been fantastic for the most part, except recently, no matter what device I plug into port4, it only is able to negotiate a link speed of 100mbps. Plugging the same exact device with the same exact cable into another port gives me gigabit full duplex with no issues.
Anyone else experienced this?
Port 4 is a passthrough for Passive Poe. Meaning that pins 4,5,7,8 are just for power. So you are left with 4 pins that will do 100Mbit max.
Port 4 (eth4) on the Edgerouter X is a PoE 24v passive port.
What you're experiencing is a limitation of passive PoE if i'm not mistaken.
"Although there's a problem on the horizon; there's no horizon." - K-2SO
Learned something new here.
I am looking at my EdgeRouter X right now, and I am only using eth0 to eth2  If I were going to use eth3 then I probably would have the same question as well.
https://dl.ubnt.com/datasheets/edgemax/EdgeRouter_X_DS.pdf if you look at page 5 of the datasheet it clearly says that the POE port does 10/100/1000. Very misleading on Ubiquiti's part.
@snowfox99 @beyonddc @dj_ripcord
Seems i was a bit hasty and based my comment on my experience with older passive POE.
Seems that a while ago passive POE also became gigabit in 2 flavors:
Version A: Pin 1/2 Data&V- , Pin 3/6 Data&V+
Version B: Pin 4/5 Data&V+ , Pin 7/8 Data&V-
Main difference with the 802.3af/at standard is that its well... passive, meaning there is no negotiation about if power is needed.
The Passive POE ports are just always on.
So port 4 is a Gigabit port, but maybe in the settings its set as something else. How are you powering the Edgerouter?
You could also try to force Gigabit in the settings
