Clock speed dropping
Go to solution Solved by Morgan MLGman,
4 minutes ago, TerminalLance98 said:
It's a Asus M5A78L-M plus. The temp gets up to 48c under load, but I can't seem to find the max temp rating for it. And I haven't seen it happen much at stock speeds.
1
It's not your CPU overheating, it's this part that delivers power to it that overheats because it has no radiators on it and it's not a good VRM as it's a budget-oriented board.
By reducing voltage supplied to the CPU it cools down, but reducing voltage means reducing clock speeds so this is why you experience performance drops under load.
So I've done some research and all I can find is that cpu clock speed dropping under load is caused usually by overheating. I have a FX 6300 (yes I need an upgrade lol) oc to 4.2 GHz with the reference at 200. It's still fairly stable at 4.5, but 4.2 seems to be the best. Idle temp is usually 20c and under load it barely breaks 40. But for some reason the clock speed alters between 3.0 and 4.2 under 100% load using prime95. Variations are seen during gaming as well, causing severe fps drops. Any ideas on the culprit?
https://linustechtips.com/topic/988701-clock-speed-dropping/
Knowing the FX-line quite well, it's most likely your motherboard's VRM section overheating and throttling the CPU to keep the temperatures of VRM modules in check.
To confirm this - what's your motherboard? Also, do the clock speed drops also happen at stock speeds?
EDIT: I just went into your profile, it's definitely your motherboard's VRM. Do not overclock on this board, it's not good-enough for that.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/988701-clock-speed-dropping/#findComment-11908395
VRM on the motherboard overheating
Desktop benching:
https://linustechtips.com/topic/988701-clock-speed-dropping/#findComment-11908397
What motherboard and voltage?
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/988701-clock-speed-dropping/#findComment-11908401
https://linustechtips.com/topic/988701-clock-speed-dropping/#findComment-11908405
Is that CPU temp or VRM temp?
That mobo isn't really meant for OC'ing.
https://linustechtips.com/topic/988701-clock-speed-dropping/#findComment-11908412
Yeah I was afraid if that. Thanks guys for the quick replies. Once I get the paychecks in I'm definitely upgrading to hopefully an 8700k with an Asus prime or something similar.
https://linustechtips.com/topic/988701-clock-speed-dropping/#findComment-11908415
1
https://linustechtips.com/topic/988701-clock-speed-dropping/#findComment-11908420
