7 minutes ago, Rt2002 said:
So, i have a VS650, a old one like 2014/15 if im not mistaken, i would like to know if it is still good today, because i want to upgrade my PC and would like to know if it would keep up to new hardware
Well wattage wise you should be good, though the VS-series is kind of trashy so to guarantee the safety of your new components get a new psu and this time maybe from the cx-series.
https://linustechtips.com/topic/988101-power-supply-gaming/#findComment-11902343
4 minutes ago, Firewrath9 said:
Get a new one. Corsair TX550m is cheap and good.
Ok, it's better to get a new one then, where can i calculate watts i'll need for the specs?
https://linustechtips.com/topic/988101-power-supply-gaming/#findComment-11902354
Just choose PSU with at least 20% extra wattage over your system theoretical needs.As bare minimum.It is never a good idea to save money on PSU.
My PC --- CPU: Ryzen 7 3700x @ 4.3 || MoBo: Asus strix x470-F || RAM:32GB@3400mhz  4x8GB Corsair vegeance pro RGB || Cooler: Corsair H150i Pro AIO || GPU: Sapphire Rx5700 XT nitro+ || PSU: Corsair rm750i || Case: Thermaltake TG 31 RGB || SSD: 1x hp ex900 nvme 500gb 3x crusial mm500 1tb || Corsair M65 elite & Corsair platinum K95 || 2x Acer ed323 qura 1440p@144hz + Samsung c27fg70 1080@144hz.tb
https://linustechtips.com/topic/988101-power-supply-gaming/#findComment-11902377
Worst PSU corsair makes based on the ancient group-regulated design so upgrading would be a nice idea
https://linustechtips.com/topic/988101-power-supply-gaming/#findComment-11902407
