No Post Everything Works Fine
Go to solution Solved by Pc Casual YF,
HDMI cable broken
    Hello there, I just built my first computer and it had no signal on the screen even though everything was working, so I used the pinned post about no signal and after trying most things (some things I didn't have another PC or another GPU, CPU, or PC to work with). So any help?
Details:
     I built a PC with all new components other than a refurbished motherboard and the I tried going into bios before I boot it with ubuntu and my GPU ( which was in a x16 pcie slot, where it is supposed to be) had not signal on the monitor but the fans did work. After that, I put it into the
x8 slot and then it worked and I booted ubuntu and everything worked other than l4d2 had like 1 fps on a 1060 6gb. After a few days I tried to boot it and now only the LEDs worked then I  removed and put back the power cables then the fans CPU and everything worked and NOW, I cannot boot the computer even though everything works.
Specs:
MB: Asus X470 Prime Pro
CPU: Ryzen 5 2600
GPU: EVGA Superclocked 1060 6GB
PSU: EVGA 550w G3
RAM: 1x8 GB Ballistix Sport
Edited by Pc Casual YF
I mad it look better
https://linustechtips.com/topic/987336-no-post-everything-works-fine/
Details:
Specs:
CPU: Ryzen 5 2600
PSU: EVGA 550w G3
Bad refurb? Who's the vendor?
Primary PC:
PSU tier list
How many watts do I need?
