Which is a better choice?
A soundbar or speakers
I saw a amazing looking soundbar in the mall today, at $99.99 and it sounds amazing too some weird brand tho (Avalon).
I was expecting to get some logitech 2.1 speakers with thx that cost me about $135.98 I know they sound amazing too because my cousin uses them as well,
I was thinking should I go for the soundbar or the speakers both have subs but the soundbar makes my table look cleaner.
Need advice I'm not good with audio tech thanks
Best Value Build List
Budget 1080p System (RGB) https://pcpartpicker.com/list/7v2Lmq - (this build comes with two free games with the RX 570)
https://linustechtips.com/topic/986890-audio-questions/
4 minutes ago, LukzForEver said:
Maybe if it has warranty pick it up
It comes with 2yrs if I remember right,
https://linustechtips.com/topic/986890-audio-questions/#findComment-11890912
depends what you want, for my PC i have a nice 30 something inch vizio soundbar, it sounds crisp and amazing, even at very high volumes.. you can get one without a wireless BASS for about 90$ i believe, or one with a wireless bass for like 130. i have the older version, but the newer one would be even better :)
and yes, the bass is WIRELESS the soundbar, just plug it in and it will connect. the soundbar also has bluetooth, as well as dolby audio e.t.c.
If my Response helped you, Please click the Check under my reply, to mark it as The Solution!
https://linustechtips.com/topic/986890-audio-questions/#findComment-11890967
Thanks
https://linustechtips.com/topic/986890-audio-questions/#findComment-11891051
