Hi,
I recently had an assignment where I needed to take a range of numbers, find which ones were prime, and then give the prime factorization of the non prime numbers. I got a relatively good grade on the assignment, but I missed out on a few points for not having asterisks in between the prime factorization. I want to figure out how to fix this but I am a bit stumped. Here is the function in question:
int factor(int test_num)
  int potential_factor;
  printf("The factorization of %d is: \n", test_num);
  for(potential_factor = 2; potential_factor <= test_num;)
    if(test_num % potential_factor == 0)
      printf("%d ", potential_factor);
      test_num = test_num / potential_factor;
    else
      ++potential_factor;
This has an output like so:
I want to make it so instead of "2 2" it would look like "2 * 2"
And also for higher numbers, like 196 for example, the factorization should look like "2 * 2 * 7 * 7"
How would I go about doing this without adding an extra asterisk at the end of the last number?
Thanks!
P.S. I can add the entirety of the code if you would like to look it over.
https://linustechtips.com/topic/986813-loop-logic-question-for-c/
you could change that to "printf("%d *", potential_factor);
but that would also add a * at the end of the last factor.... maybe set a if statement saying if it is the last factor, : printf("%d ", potential_factor);
You could either:
  • Have it evaluate the first factor, then in the loop the first thing it does is print an asterisk.
  • Have the loop check if the exit condition fails and if it does, print an asterisk.
I prefer the first one over the second if only because the algorithm is not having to evaluate another if-statement in the loop. You just have to remember to adjust the initial value of potential_factor
