I got this issue where when I try to select 144hz as my refresh rate, but it automatically reverts back to 60hz. I have tried numerous 'tips' from reddit etc. but nothing seemed to solve my issue. I tried the 'set to lower resolution'. I try with CRU and adding a lower hz.
If anyone maybe has any further suggestions, I am glad to hear them!
https://linustechtips.com/topic/986341-bo4-pc-refresh-rate-issue/
What refresh rate is your monitor? What display cable are you using?
Primary PC:
PSU tier list
How many watts do I need?
If game sees his 144Hz, its probably sufficient
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
