My problem:
   My pc seems stable but crashes about once a month at a totaly random thing.
   When this happens the screen freezes and a colored noise comes over it.
   The audio also becomes extremely loud noise.
   I thought that it was the heat but i ran a gpu benchmark and a ram test simultaneously for hours without any errors.
   I can run benchmarks all day without any error, or so i thought until i looked at the memtest screen this morning.(i let it run at night)
   It showed the included screen, 10k+ errors only on test 6, range (1200mb - 22000mb).
   Are these false positives?
   What can i do to get to the cause of the problem?
My specs:
   CPU: i7-8700k
   MB:   asus z370-e
   RAM: 24gb crucial ballistix sport (BLS4G4D240FSA.8FADG *2 and BLS8G4D240FSA.M16FAD *2)
   GPU: gigabyte 1080ti
   SSD: Samsung 970 evo 500gb
   all at stock with ram at the xmp profile of 2400mhz (the only one it has)
Thanks in advance,
Jannick
https://linustechtips.com/topic/986152-need-help-troubleshooting/
Pull out your ram sticks and test them 1 by one, I suspect a bad stick.
My rig:
CPU: Ryzen 7 5800x
MB: Gigabyte B450 I Aorus Pro WiFi
RAM: Kingston Fury Beast RGB 32GB (2x16GB) 3600mhz CL16 (1-to-1 Infinity Fabric enabled)
GPU: Gigabyte RTX 2080 Super
*bought for $200 CAD off a friend who needed an RTX 3080, price was my reward.
CASE: InWinn A1 Plus in White with included 600w gold sfx PSU and included custom length cables
DISPLAY: 3x 20" AOC 1080p 60hz 4ms ,  32" RCA 1080p/60hz TV mounted above, all on a single arm.
Storage: C : 1TB WD Blue NVMe      D : 2TB Barracuda      E: 240GB Kingston V300 (scratch drive)
NAS: 240GB Kingston A400 + 6x 10+ year old 700GB Barracuda drives in my old FX8350+8GB DDR3 system
Logitech G15 1st Gen + Logitech G602 Wireless
Steam Controller +  Elite Series 2 controller + Logitech G29 Racing Wheel + Wingman Extreme Digital 3D Flight Stick
Sennheiser HD 4.40 Headphones + Pixel Buds 2 + Logitech Z213 2.1 Speakers
My Girlfriends Weeb-Ass Rig:
Razer Blade Pro 17 2020
10th Gen i7 10875H 8c/16t @5.1ghz
17.3" 1080p 300Hz 100% sRGB, factory calibrated, 6mm bezel
RTX 2070 Max-Q 8GB
512GB generic NVMe
16GB (2x8GB) DDR4 3200Mhz
Wireless-AX201 (802.11a/b/g/n/ac/ax), Bluetooth® 5.1, 2.5Gbit Ethernet
70.5 Whr Battery
Razer Huntsman Quartz, Razer Balistic Quartz, Razer Kraken Quartz Kitty Heaphones
*deep breath*
Razer Raptor 27" monitor, IT'S BEAUTIFUL.
That's just the memory area they were testing at the time of the errors, it doesn't mean that entire area is bad.
Stick by stick method 100% recommended. It's a pain in the butt but worth it in the end.
If a set of ram is newer than the others just test that pair together to save time, then you can narrow it down to them individually if it fails.
My rig:
CPU: Ryzen 7 5800x
RTX 2070 Max-Q 8GB
512GB generic NVMe
70.5 Whr Battery
*deep breath*
Should i do all the tests or just test 6?
since all the errors were on test 6
Nah do all the tests again
My rig:
CPU: Ryzen 7 5800x
RTX 2070 Max-Q 8GB
512GB generic NVMe
70.5 Whr Battery
*deep breath*
