I have a msi b350m gaming pro motherboard for my first build, this is my parts list.
What do you guys think of what I have planned.
This is a budget build that I am trying to keep under 800$.
https://linustechtips.com/topic/986057-building-my-first-pc/
I think that looks super solid. Don't let any elitists tell you a tier 4 PSU isn't good enough, cause I can hear it already.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/986057-building-my-first-pc/#findComment-11882597
Just now, Flawizz said:
go for cx450m psu
r3 1300x
cheapest 120gb ssd for OS
cheapest 1tb hdd for games etc...
try to find 3200 or atleast 3000mhz ram :)
No need for any of that stuff. Storage can be upgraded later, nice big SSD reads and writes faster, PSU doesn't need replacing, r3 1200 can be overclocked to match 1300 on stock, and ryzen 3 doesn't worry about infinity fabric so faster ram is not important. (not like 2800 is slow)
Primary PC:
PSU tier list
https://linustechtips.com/topic/986057-building-my-first-pc/#findComment-11882600
tru, but he says first build so i wouldnt get into oc. anything can happen. and perhaps save some $$ on psu with less watt :)
https://linustechtips.com/topic/986057-building-my-first-pc/#findComment-11882608
nah, a mild overclock is safe and a good skill to have early on. Also, getting bottom of the barrel cheap storage isn't necessarily better.
Primary PC:
PSU tier list
https://linustechtips.com/topic/986057-building-my-first-pc/#findComment-11882622
he on a budget tho, which means if oc goes wrong, it voids warranty and dead cpu, no money cause on budget, but ok just suggesting :)
never said cheap storage is better, it will do the job, as i said he's on a budget :D
https://linustechtips.com/topic/986057-building-my-first-pc/#findComment-11882632
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  ($159.89 @ OutletPC) 1600 if your board hasn't been updated yet.
Motherboard: MSI - B350M GAMING PRO Micro ATX AM4 Motherboard  (Purchased For $0.00)
Memory: G.Skill - Aegis 16GB (2 x 8GB) DDR4-3000 Memory  ($114.99 @ Newegg)
Storage: MyDigitalSSD - 80mm BP5e 480GB M.2-2280 Solid State Drive  ($79.99 @ Amazon)
Video Card: PowerColor - Radeon RX 580 8GB Video Card  ($209.99 @ Newegg)
Case: Thermaltake - Core V21 MicroATX Mini Tower Case  ($63.09 @ Amazon)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($38.98 @ Newegg)
Total: $666.93
Generated by PCPartPicker 2018-10-22 21:56 EDT-0400
https://linustechtips.com/topic/986057-building-my-first-pc/#findComment-11883047
Yeah I am planning on upgrading a few things later I just want to get started building already.
https://linustechtips.com/topic/986057-building-my-first-pc/#findComment-11883078
29 minutes ago, Kitty47 said:
Thanks I was thinking of going for the Blue
Do not do WD blue, it is a cachless drive and will be slower and die faster than an EVO.
Rest In Peace my old signature...                  September 11th 2018 ~ December 26th 2018
https://linustechtips.com/topic/986057-building-my-first-pc/#findComment-11883164
