Been saving for a while now and decided to build a new rig for the first time in 8 years.
My budget is between $2500-$3000 USD but needs to include a new monitor as well.
This rig will primarily be for gaming and occasional software development. I'm trying to look for a CPU to be able to support both with a decent price point. I do want to try to hit 32 GBs of RAM because I've had issues with only 16 GBs on my work laptop when coding. I like the idea of having no typical hard drives with SSDs in the machine. For gaming I want to push 1440p with graphics set rather high, I like games such as The Witcher 3, some RTS, and really looking forward to Cyberpunk 2077. I do like FPS but am not a competitive gamer so the highest FPS isn't a strict requirement.
Below is my idea of AMD rig to fit my needs. I'm very torn on what GPU to get due to the reviews and availability at any given point. I have a 2080 on the list but i'm not entirely set on that item. I do want to have gsync on an IPS screen.
PCPartPicker part list: https://pcpartpicker.com/list/DVZWP3
CPU: AMD - Ryzen 7 2700X 3.7GHz 8-Core Processor
Motherboard: Asus - Prime X470-Pro ATX AM4 Motherboard
Memory: G.Skill - Ripjaws V Series 32GB (2 x 16GB) DDR4-3200 Memory
Storage: Samsung - 970 Evo 500GB M.2-2280 Solid State Drive
Storage: Crucial - MX500 1TB 2.5" Solid State Drive
Video Card: EVGA - GeForce RTX 2080 8GB XC GAMING Video Card
Power Supply: EVGA - SuperNOVA G2 750W 80+ Gold Certified Fully-Modular ATX Power Supply
Monitor: Asus - PG279Q ROG Swift 27.0" 2560x1440 165Hz Monitor
Other items needed.
  • Case: I'm not sure on cases at all. I do want a case with easy cable management and can fit the components
  • OS: I'll be looking into getting a license for Windows 10. I'll take any recommendation on which version to get. As well as easiest way to buy!
  • Keyboard/Mouse: I have some I can reuse but I'll take recommendations here as well.
  • Speakers/Headset: Looking for both!
https://linustechtips.com/topic/985123-first-build-in-8-years/
- Get a Fractal Design Meshify C case
- Get a Arctic Freezer 33 eSports ONE or Dark Rock Pro 4 CPU cooler
- Get a 1080 Ti instead of the RTX 2080
- For mouse, get a Logitech MX Master 2s (it's very comfortable to hold) or a G502 if you need a lot of buttons
- For keyboard, you'll have to try out different key switches for yourself (I like Cherry MX Browns but others say Cherry MX Blues are better)
- I'd also get a Corsair RM750x PSU instead
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/985123-first-build-in-8-years/#findComment-11874438
I mostly agree, although I wouldnt suggest a corsair PSU myself. EVGA is my go to.
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/985123-first-build-in-8-years/#findComment-11874470
I'd go with Intel, and Corsair PSU is great too.
Type Item Price
CPU Intel - Core i7-8700K 3.7GHz 6-Core Processor $369.99 @ Amazon
CPU Cooler Corsair - H100i v2 70.7 CFM Liquid CPU Cooler $74.99 @ Newegg
Motherboard Asus - Prime Z370-A ATX LGA1151 Motherboard $159.99 @ Amazon
Memory Corsair - Vengeance LPX 32GB (2 x 16GB) DDR4-3200 Memory $285.99 @ Newegg
Storage Samsung - 860 Evo 1TB 2.5" Solid State Drive $162.99 @ Amazon
Storage Samsung - 860 Evo 1TB M.2-2280 Solid State Drive $162.99 @ Amazon
Video Card Gigabyte - GeForce GTX 1080 Ti 11GB Gaming OC 11G Video Card $704.98 @ Newegg
Case NZXT - H500 (Black) ATX Mid Tower Case $69.99 @ Amazon
Power Supply Corsair - RMx (2018) 850W 80+ Gold Certified Fully-Modular ATX Power Supply $79.99 @ Newegg
Operating System Microsoft - Windows 10 Home OEM 64-bit $94.89 @ OutletPC
Monitor Acer - Predator XB1 27.0" 2560x1440 165Hz Monitor $499.99 @ Amazon
Keyboard Corsair - K68 RGB Wired Gaming Keyboard $89.99 @ Amazon
Mouse Logitech - G502 Proteus Spectrum Wired Optical Mouse $49.97 @ Amazon
Headphones Sennheiser - HD 280 PRO Headphones $99.95 @ Amazon
Other Razer Seiren X - Professional-Grade High-Definition Studio Sound USB Digital Condenser Microphone - Optimized for Streaming Twitch/Youtube - Built-In Shock Mount $98.80 @ Amazon
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $3055.49
  Mail-in rebates -$50.00
  Total $3005.49
  Generated by PCPartPicker 2018-10-20 09:50 EDT-0400
Rest In Peace my old signature...                  September 11th 2018 ~ December 26th 2018
https://linustechtips.com/topic/985123-first-build-in-8-years/#findComment-11874495
Pretty solid choice; just FYI though 8700k/9700k may be a little better. Gaming performance might be a few % better and compile performance I believe is usually pretty similar. Both CPUs are a little more expensive though so it's up to you to judge whether or not you would want to pay an extra $60-$100 for what's most likely going to amount to 5% better gaming performance at most.
I feel like an NVMe drive would be a bit unnecessary. At least for storing OS And apps it'd be a waste of money as a solid SATA SSD would do just as well in those regards. I'm not sure how much it might benefit software development though. If it doesn't really matter I would just grab a single 2tb MX500; if it does matter I would suggest this cheaper NVMe SSD that I would consider just as good as the 970 evo
https://pcpartpicker.com/product/GQL48d/adata-xpg-sx8200-480gb-m2-2280-solid-state-drive-asx8200np-480gt-c
Just FYI 1080 tis do start about $100 cheaper so that's something you could consider.
I would personally grab this cheaper 650w RMx instead
https://pcpartpicker.com/product/Rp8H99/corsair-power-supply-cp9020091na
Or this 850w for the same price
https://pcpartpicker.com/product/VgQG3C/corsair-rmx-2018-850w-80-gold-certified-fully-modular-atx-power-supply-cp-9020180-na
Either one should also be quieter.
You could probably save a bit of money by getting one of these two monitors instead.
https://pcpartpicker.com/product/ttnG3C/acer-monitor-xb271hubmiprz
https://pcpartpicker.com/product/scM323/aoc-ag271qg-270-165hz-monitor-ag271qg
As for case, I'm not quite sure what you want the case to look like but the Fractal Design Define R6 is a solid all around case that's not too flashy.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/985123-first-build-in-8-years/#findComment-11874505
