Many Building Questions
1. not needed
2. wont degrade
3. no need to clean, but most cpu coolers have pre-applied paste - no need to add more. If you ever need to clean later, use isopropyl alcohol. water will cause problems if it gets on components/motherboard.
4. keep your cat away while you build. - they tend to carry a lot of static electricity
5. shouldn't be too bad but try to avoid - dust filters will keep it out. You want to keep as much dust/fur buildup out of the pc as possible
6. Post means turns on - can get to bios
7. Ram is weird
8. shouldn't have to tweak anything in first boot. Get drivers installed first and then you can play in bios
9. mobo brick equals dead. Usually from being shorted out. don't let the back come in contact with any unwanted metal. Standoffs are important but most cases have the standoffs already installed
10. If you buy old hardware, you should update the bios when you first install. I usually don't flash the bios unless i'm having issues.
