Hi, I'm looking around at GPU's and I'm wondering, is this information correct?:
https://pcpartpicker.com/product/XYDzK8/asus-radeon-rx-580-4gb-dual-video-card-dual-rx580-o4g
It says that this RX 580 has 4GB of VRAM, which doesn't seem right, I always thought that RX 580's always had 8GB of VRAM?
https://linustechtips.com/topic/984593-rx-580-help/
RX 580s can either have 4 or 8GB of VRAM, that product is legit.
 CPU: I9-7900X RAM: 64GB (16X4) DDR4-2933 GPU: RTX 3080 MOBO: ASUS X299 Deluxe PSU: Corsair RM850 SSD: ADATA XPG SX8200 PRO 1TB HDD: Seagate Barracuda 2TB Case: Corsair iCUE 465X Cooler: Corsair 280 AIO
https://linustechtips.com/topic/984593-rx-580-help/#findComment-11869998
Is a dual so it can run with another one
It is legit tho
https://linustechtips.com/topic/984593-rx-580-help/#findComment-11869999
There are 2 variants of the 580 (well there's 3 now, but the new one is just a 570). One with 8gb VRAM and 4gb.
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/984593-rx-580-help/#findComment-11870001
Just now, Lordclouds said:
Is a dual is meant to run with another one 4+4=8
No.
Also thats not how crossfire works. You dont add the VRAM.
Dual is just ASUS branding for their cards with 2 fans.
https://linustechtips.com/topic/984593-rx-580-help/#findComment-11870004
