OC Fan Speed Problem
Go to solution Solved by LogicalDrm,
11 hours ago, Frostling said:
Actually, I don't care too much about the noise either way since I have a air conditioner running 24/7. I just want to actually know will it actually wear my components or not.
Ofc it will. But fans are rated to run 100% all the time. If your fan has 5000h operating time, thats fan running 24/7 at full speed for 208 days. If fan runs at lower speeds, lifetime will be tad longer.
Only way to reduce lifetime would be overvolting it. Which you can't do with consumer mobos.
Your fans are fine and designed to run at 100% rpm. If it's too noisy, edit your fan curve.
https://linustechtips.com/topic/984537-oc-fan-speed-problem/#findComment-11869515
Just now, WoodenMarker said:
No. It's it's too noisy, edit your fan curve.
https://linustechtips.com/topic/984537-oc-fan-speed-problem/#findComment-11869523
if your fan wears out early from running at 100%, you have bought a shitty fan.
https://linustechtips.com/topic/984537-oc-fan-speed-problem/#findComment-11869531
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/984537-oc-fan-speed-problem/#findComment-11870811
