Hello,
I need your help,
Im trying to fix an old pc for a teacher that has 0 idea about computers.
The pc wont turn on, its probably a psu issue. I want to replace the psu but the thing is that she has no clue about the model of the pc / motherboard and neither do i. And it looks like a prebuilt.
It doesn't even say anywhere on the case whether its a dell or an hp pc.. No clue.
Anyway, so if i want to replace the psu, how am i gonna do the wiring? Front panel wiring is gonna be like a guessing game right? Any ideas?
Thank you.
https://linustechtips.com/topic/984064-old-pc-need-repair/
If it's a PSU problem, just buy another PSU provided the case doesn't need some wonky proprietary design.
What happens when you try to power on?
https://linustechtips.com/topic/984064-old-pc-need-repair/#findComment-11864968
20 minutes ago, lior1111 said:
Hello,
I need your help,
Thank you.
Take the side panel off the system, post a full, clear, pic of the motherboard here, and we can help.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/984064-old-pc-need-repair/#findComment-11864990
Don't touch front panel. Those are connected to the motherboard and not the PSU. Also, are you certain the problem is the power supply? There could be any number of issues.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/984064-old-pc-need-repair/#findComment-11865036
Alright, i will when i can
Pretty sure man, the pc just doesnt show any signs of life and electricity.
https://linustechtips.com/topic/984064-old-pc-need-repair/#findComment-11865263
Could still be the motherboard. If front panel power button doesn't do anything, the system won't try to power on.
Primary PC:
PSU tier list
https://linustechtips.com/topic/984064-old-pc-need-repair/#findComment-11865268
There you go. Sorry it took me a while
https://linustechtips.com/topic/984064-old-pc-need-repair/#findComment-11888288
That's a blurry shot, but as near as I can tell, it's a standard micro-ATX board with a 4pin CPU power plug and a standard 24pin for main power. Any modern power supply will have those connectors. Don't touch anything else but the power plugs going into the board, and you'll find out quickly if it's the PS or something else.
https://linustechtips.com/topic/984064-old-pc-need-repair/#findComment-11888330
The motherboard may still be to blame, so if you have a loaner power supply, I'd recommend testing that. You can also just check the connections to the components from the PSU.
Primary PC:
PSU tier list
https://linustechtips.com/topic/984064-old-pc-need-repair/#findComment-11888477
