No. Your best bet is probably the 95W Phenom II X6, like the 1055T and 1035T.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/984058-will-am3-fit-am3/#findComment-11864857
If I'm not mistaken, the best CPU you can technically put in a 570 is the Phenom II X4 965, so that'd be a hard no on any FX chip.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/984058-will-am3-fit-am3/#findComment-11864863
40 minutes ago, VoxelCode said:
So would the AMD fx-8350 fit?
It would fit (socket is compatible), but the system won't start because the BIOS doesnt recognize the CPU. AM3+ support is limited on AM3, only selected boards can do this.
AM3+ CPUs have thicker pins and 2 extra pins, so no it won't fit. The compatibility is the opposite: AM3+ mobo with AM3 CPU works flawlessly, not the other way around
Desktop benching:
https://linustechtips.com/topic/984058-will-am3-fit-am3/#findComment-11864975
