Building a system for the moment which will be predominantly used as a high end media box/work station since it'll be in my living room for the foreseeable future but I want the ability to run something like Red Dead 2 if PC released.
Would I be foolish to go for GTX 1060/1070 or should I pile onto a RTX 2070? Most likely be running on a 60 hertz 1080 TV for now until I can set up a proper area to house the machine permanently.
CPU: Intel i-9 9900KF
Motherboard: Gigabyte Z390 Aorus Master
RAM: G.Skill 32GB 3200MHz Sniper X
GPU: ASUS ROG Strix RTX 2060
Case: Fractual Design Define S
Storage: Intel 760p 265GB SSD x2, Intel 760p 1TB SSD
PSU: Aerocool Project 7 650W
Display: ASUS VG278QR
Cooling: Noctua D-15S
Sound: ASUS Strix Soar
OS: Windows 10
https://linustechtips.com/topic/984001-red-dead-ready/
1 minute ago, peacefulpolarbear said:
I’d avoid the RTX cards unless you specifically want ray tracing.
Anything from a 1070-1080ti would probably be good, depending on how much you want to spend.
€400ish would be the budget
OS: Windows 10
https://linustechtips.com/topic/984001-red-dead-ready/#findComment-11864364
