You always use the port on the dedicated graphics card. If that's not present in your system or you have display issues with your GPU, you can connect it to the motherboard so the display goes through the integrated GPU for troubleshooting.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/984000-help-please/#findComment-11864342
