So my friend had a m.2 SSD he wanted hooked up for a while now and I got it working today and installed windows fresh onto it. But I had to enable M.2 Mode in the bios settings to get it to actually detect the SSD but I think it is causing the wifi adapter to not work but now we have windows installed on the SSD so i was wondering if there is some way around this.
Thanks for any replies in advance.
https://linustechtips.com/topic/983921-wifi-adapter-not-working/
Have you tried adapting the wifi?
Download wifi adapter drives from another pc, shove it onto a usb stick and install on the machine ur having issues with.
Can you disable / enable the wifi adapter in the uefi?
Currently running with a MacBook Pro 14 2021, may build or pick up a gaming laptop again in the future.
