Case - Define mini c Link
exhaust- nf p-12 1700rpm (Redux) Link
intake - 2 Dynamic X2 GP-12 Link
The intake fans don't move air so i feel my cpu cooler and gpu maybe be suffocated.
i'm happy to replace all of them :D, i plan to switch a nh-u12s if that matters.
£20 each fan if possible, i most want silence and air flow as they'll be case fans.
I may be wrong.
https://linustechtips.com/topic/982917-case-fans/
1 minute ago, Altruist said:
Not all fans are loud when moving lots of air.
yeah I'm sure a ceiling fan on 30 volts is super quiet.
Unless you plan on cutting a larger hole in the case you will hit a threshold of the amount of air you can movie without making noise
https://linustechtips.com/topic/982917-case-fans/#findComment-11853891
How are you determining that they're not moving air? Are your temps too high?
https://linustechtips.com/topic/982917-case-fans/#findComment-11854570
19 minutes ago, Altruist said:
The gap between cpu and gpu and the front lacks air flow, atleast to the touch of my hands
Your hands are not a good tool for measuring airflow. Look at your temps instead.
https://linustechtips.com/topic/982917-case-fans/#findComment-11854713
