Red flickering pixels (no issue with the screen itself).
Dudis
So i think i have damaged my HDMI port, but i would love to get peoples thoughts on it.
I was cleaning my desk and accidentally unplugged an HDMI from the back of my laptop. I plugged it back in and noticed that my second monitor was flashing with red pixels, kinda like this:
It mostly appears in blue and gray gradients.
I tried changing the cable - Same issue
I tried connecting another HDMI screen to my laptop - Same issue
I tried plugging the monitor into another PC (with the same cable) - Issue gone
So the issue cant be my monitor or HDMI cable, it has to be my PC. Would that leave a damaged HDMI port as the most plausible explanation?
The screen doesnt have Displayport, so I cant test that. I searched the web and found a lot of people fixed similar issues by changing color settings, but I have tried playing around in the Nvidia control-panel, which moves the pixels around to new areas, but does not fix the issue.
Is there anything else i should try or that I havnt thought about?
Thank you guys in advance!
I think I've found some sort of a solution:
I changed the color format from RGB to YCbCr422 and the issue seems to be gone. YCbCr444 gave me similar flickers but in Cyan-ish instead of red.
I'm still interested in your thoughts on what could have caused this, but this is mostly "solved" (bandaided) now i suppose :)
Correction, issue is not solved, just better...
