Hello!
Problem: The H100i LED suddenly started to cycle between yellow and white, and I can't change it in the Corsair Link software, because the light "switch" does not work anymore (see image).
                I used to have it this way perhaps two months ago, but it looks really ugly xD I don't know what might have caused the problem, and i can't find anything on the interwebz to help me. I have re-installed the Link software, and ensured that all connectors are OK.
Corsair Link version 2,4,5110
H100i FW version 1,0,7
General Specs:
CM Storm Stryker
Corsair AX760i
MSI MPower z77
MSI GTX 680 lightning
Intel i7 3770k
Corsair H100i w/Noctua NF-F12's
Avexir Core series MPower edition 32gb
ASUS Xonar DGX
Samsung 840 pro 256gb
Seagate Barracuda 2tb
Bitfenix white sleeved cables (yep, even the front panel audio)
Silverstone Air penetrator 120mm
With Windows 8, 64bit
Any help would be greatly appreciated  ;)
https://linustechtips.com/topic/98207-h100i-strange-led-issue/
This may be a dumb question but how did you get Corsair Link to display a CM Storm Stryker as your case? LOL!
FX 8150 @ 4.0 GHz, MSI Radeon 7850 OC Edition, 2 x 4 gigs of GSkill Sniper ddr3 at 2133 MHz, two 120 gig Kingston HyperX 3K ssds, Crosshair V Formula, Antec High Current Gamer 620 watt psu, all wrapped up inside a Cooler Master CM Storm Stryker.
https://linustechtips.com/topic/98207-h100i-strange-led-issue/#findComment-1314178
