Help!
Go to solution Solved by Oshino Shinobu,
It will do 1080p through DVI. Some monitors won't support full RGB through HDMI, so DVI is better (+ locking connector). Only thing is that DVI-D doesn't have audio.
EDIT: Sometimes HDMI doesn't support full RGB by default. You can change it in settings or get a program that changes it automatically.
so i was looking at this monitor  and it talks about full HD with hdmi, so does that mean that i can't do 1080p on DVI-D even thought the connector supports it. Also is there a noticeable difference between DVI and hdmi? And another thing i'm using vga on my 19 inch tv and the rez only goes up to 1360 x 768 and once again i know VGA can go higher, cable, tv?
P.s is the tv any good?
Thanks
Something Awesome!
https://linustechtips.com/topic/98195-help/
You should be able to use DVI and 1080p.
https://linustechtips.com/topic/98195-help/#findComment-1313697
True Resolution : 1920x1080
Full HD 1080P : Yes
Signal Input : HDMI , D-Sub, DVI-D
Conclusion: It will.
ヽ༼ຈل͜ຈ༽ノ raise your dongers ヽ༼ຈل͜ຈ༽ノ
It feels as though no games ever leave the BETA stage anymore, until about 3 years after it officially releases. - Shd0w2 2014
https://linustechtips.com/topic/98195-help/#findComment-1313703
https://linustechtips.com/topic/98195-help/#findComment-1313708
very interesting, don't need audio i either use my Sony dock or headphones, thank you very much!  :)
Something Awesome!
https://linustechtips.com/topic/98195-help/#findComment-1313768
