Hi, i have a R5 1600, with the box cooler. Are these Temps normal?
Idle: 36C - 38C
under Load: 74C - 79C
I did not OC the CPU. The FAN setting is on Default, and i changed the thermopaste (not like "The Verge"). I heard, that the Temps should stay under 72C. I want to use the CPU for a very long time, so is it a good idea to OC? If yes, how high should the temps go without damaging anything? (The Bottleneck of the PC is my RX580 8GB)
Thx for your Help!
https://linustechtips.com/topic/981772-cpu-temps/
With the stock cooler, those temps are fine
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/981772-cpu-temps/#findComment-11844083
3 minutes ago, Harkulles said:
Will it damage the CPU, if i keep using it like this?
no, once your temps start reaching above 90 then you should worry
https://linustechtips.com/topic/981772-cpu-temps/#findComment-11844104
5 minutes ago, buchi18 said:
No if u dont OC it the temps are fine.
Get something like a Dark Rock 3 or 4 AND Ocing schouldnt be a prob
those are good options, but kinda expensive. but if you want to overclock it without hurting the cpu, you'll need a new cooler.
https://linustechtips.com/topic/981772-cpu-temps/#findComment-11844116
1 minute ago, Lord Letto said:
I thought the Ryzen stock coolers were good & would allow some OCing? OP is likely talking about the AMD Wraith Spire Cooler (no LED) that comes with the Ryzen 5 1500X, 1600 & 2600X.
https://www.amd.com/en/technologies/cpu-cooler-solution
they're good non overclocked, but if you want to oc, then it is recommended to purchase a new cooler
https://linustechtips.com/topic/981772-cpu-temps/#findComment-11844170
For reference I'm running R5 1600 at 3.8Ghz 1.35V with stock cooler at stock curve, it stays around 60-63c when playing CPU heavy games. But I do have solid case cooling.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
https://linustechtips.com/topic/981772-cpu-temps/#findComment-11846814
Hi :)
I have the Sharkoon VG5-W https://pcpartpicker.com/product/cqQG3C/sharkoon-vg5-w-red-atx-mid-tower-case-vg5-w-red
I think that the Airflow is bad, because of the stock exhaust fan.
Can u recommend budget friendly (roughly 10€) Exhustfan for the case?
(Germany, ebay.de, amazon.de ...)
https://linustechtips.com/topic/981772-cpu-temps/#findComment-11853610
i have max 65c during AC Odysse, but is goes up when i do some editing and stuff
https://linustechtips.com/topic/981772-cpu-temps/#findComment-11853778
42 minutes ago, Pangea2017 said:
80° is not bad and don't justify upgrading the fan if you are on a budget.
Noise might improve but temp should only drop by a few degree and this don't gain you much more performance.
Btw. did you already adjusted the fan curve?
I dont know what to aim for, when i adjust the curve. Do u know a tutorial that i can watch?
https://linustechtips.com/topic/981772-cpu-temps/#findComment-11853975
