Hi all, first post here so I hope I include all the necessary info.
Finally decided to move to PC gaming after a few years of misty eyed window shopping. I have never owned more than a laptop for gaming on PC wise, currently using one with a GT525m, and yes it hurts. Never planned or assembled a PC before but willing to give it a shot so after teaching myself the basics and making the list i'm looking to get any final pointers.
Budget / Location
Building in Australia with a budget of up to $5000 AUD. Currently its a tiny bit over that but i'm ok with that but not with too much more over.
Aim
Plan on playing a far range of games on it, some medium range others more demanding. (I can run Space Engineers right now at 15fps on the lowest settings with some funky resolution settings) Hope to run most games on the highest settings I can on the listed 1440p / 144htz monitor. I know it wont fill that out in everything on high settings but close is close enough for me.
Monitors
Just the one listed monitor at 1440p. Possibly adding a 2nd monitor later, just a cheap 1080p one for side stuff but that's far down the line.
Peripherals
I'm gonna hate myself later but i'm giving in and blowing a bit more than i really need (across the whole build really). Listed a Glaive RGB and K70 Mk2 RGB both from Corsair, hope to sync RGB with the ram and fans in the build. The speakers though are just some cheap ones to supplement the terrible speakers on the monitor. For most games I plan to use my good existing headphones but the speakers will just be YouTube and Netflix gear.
Why are you upgrading?
Only ever played console and got tired of seeing games on PC I cant play, got a lot of games I have my eye on and ones I might re-buy just to play them on PC
Here is the list:
PCPartPicker part list: https://au.pcpartpicker.com/list/ZjdpFt
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($589.00)
CPU Cooler: CRYORIG - R1 Universal 76.0 CFM CPU Cooler  ($109.00)
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste  ($11.00)
Motherboard: Asus - ROG STRIX Z390-F GAMING ATX LGA1151 Motherboard  ($379.00)
Memory: Corsair - Vengeance RGB Pro 16GB (2 x 8GB) DDR4-3000 Memory  ($259.00)
Storage: Samsung - 860 Evo 500GB 2.5" Solid State Drive  ($119.00)
Storage: Western Digital - BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive  ($185.00)
Video Card: Asus - GeForce GTX 1080 Ti 11GB STRIX GAMING OC Video Card  ($1349.00)
Case: Corsair - Crystal 460X RGB ATX Mid Tower Case  ($189.00)
Power Supply: Corsair - RMx 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($175.00)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($165.00)
Case Fan: Corsair - LL120 RGB LED 43.2 CFM  120mm Fan  ($39.00)
Case Fan: Corsair - LL120RGB LED (Three Fans With Lighting Node PRO) 43.2 CFM  120mm Fans  ($149.00)
Monitor: Acer - XB271HU bmiprz 27.0" 2560x1440 165Hz Monitor  ($899.00)
Keyboard: Corsair - K70 RGB MK.2 Wired Standard Keyboard  ($229.00)
Mouse: Corsair - GLAIVE RGB Wired Optical Mouse  ($99.00)
Speakers: Logitech - Z213 7W 2.1ch Speakers  ($45.00)
Total: $5067.00
I wrote in custom prices, getting everything from PC Case Gear and PCPP doesn't have their prices for everything. I would get stuff from stores in my local area but they either don't sell anything good or its much pricier.
Some stuff wont list on PCPP so ill put those here:
Corsair Commander Pro - $99
Corsair Lighting Pro Expansion Kit - $59
Any feedback would be greatly appreciated.
Is the motherboard overkill? Only looking at the Z390 because nowhere near me lists the Z370 anymore.
Thoughts on the CPU cooler? Picked it for the clearance it should give me for the really tall RAM.
Stop me before I do something stupid! Thanks!
https://linustechtips.com/topic/981692-first-build/
pccasegear shows 8th gen mobo still in stock, is it too expensive to get just the mobo shipped? Cos you would probably save some money there.
Otherwise it is all g
Current Build
CPU: AMD Ryzen9 5900X
CPU Cooler: Deepcool Gamerstorm Captain 240 Pro
Motherboard: ASUS ROG STRIX X470 Gaming-F
Memory: G.Skill Trident Z Neo RGB F4-3600MHzC16D 2x16GB
Video Card: EVGA 3080Ti FTW3
Case: Phanteks ECLIPSE P400 ATX Mid Tower Case
Power Supply: EVGA SuperNOVA G2 850W 80+ Gold Fully Modular
Case Fans: 2x Noctua NF-P14s redux-1500 PWM 78.7 CFM  140mm Fan
Monitor: HP x34
              LG 29UM69G
Mouse: Razer Basilisk
Keyboard: Razer Blackwidow Chroma V2
Controller: GameSir Tarantula Pro
Headphones: Sennheiser IE200 + Fiio BTR5 2021
Speakers: Logitech Z200 2ch Speakers
OS: Windows 11
https://linustechtips.com/topic/981692-first-build/#findComment-11843307
Type Item Price
CPU Intel - Core i7-8700K 3.7GHz 6-Core Processor $589.00
CPU Cooler CRYORIG - R1 Universal 76.0 CFM CPU Cooler $109.00
Thermal Compound Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste $11.00
Motherboard Asus - ROG STRIX Z370-F GAMING ATX LGA1151 Motherboard $379.00
Memory Corsair - Vengeance RGB Pro 16GB (2 x 8GB) DDR4-3000 Memory $259.00
Storage Samsung - 860 Evo 500GB 2.5" Solid State Drive $119.00
Storage Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive $84.00 @ Shopping Express
Video Card Asus - GeForce GTX 1080 Ti 11GB STRIX GAMING OC Video Card $1349.00
Case Corsair - Crystal 460X RGB ATX Mid Tower Case $189.00
Power Supply Corsair - RMx 750W 80+ Gold Certified Fully-Modular ATX Power Supply $175.00
Operating System Microsoft - Windows 10 Home OEM 64-bit $165.00
Case Fan Corsair - LL120 RGB LED 43.2 CFM 120mm Fan $39.00
Case Fan Corsair - LL120RGB LED (Three Fans With Lighting Node PRO) 43.2 CFM 120mm Fans $149.00
Monitor Acer - XB271HU bmiprz 27.0" 2560x1440 165Hz Monitor $899.00
Keyboard Corsair - K70 RGB MK.2 Wired Standard Keyboard $229.00
Mouse Corsair - GLAIVE RGB Wired Optical Mouse $99.00
Speakers Logitech - Z213 7W 2.1ch Speakers $45.00
  Prices include shipping, taxes, rebates, and discounts
  Total $4966.00
  Generated by PCPartPicker 2018-10-11 16:53 AEDT+1100
Saved you over $100 and brought the system under budget just by replacing the stupidly overpriced WD Black 2TB with another 2TB HDD.
https://linustechtips.com/topic/981692-first-build/#findComment-11843338
You can always look for a used 1080 Ti. Most of them will be ex-mining cards, but if you're lucky you can find one that was either used sparingly, or just for gaming. I found one used for about 35% off new price, and it has 2 years left on warranty. Other than that, looks good. Also, I'd wait for the 9000 series to be in stock, cause the price of the 8000 series will likely come down, even just a little. But if you have 5 grand to blow you probably don't care much about $20
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/981692-first-build/#findComment-11843369
