Hey guys I have a ryzen 7 1700x with a old cooler and a msi rx580 8gb with the one fan so, my Temps on the cpu aren't bad and if overclock my cpu I don't think it will make a big difference so I was looking to water Cool my gpu first but at a cheap price how can I do this. Also any recommendations on doing it differently.
https://linustechtips.com/topic/981666-need-help-with-water-cooling/
NZXT Kraken G12 and an AIO is likely the cheapest watercooling you can get for your GPU without sacrificing quality.
Honestly? Its not worth watercooling that GPU. You simply spend more on the cooling then youd actually gain in performance.
