so a few days ago my pump just stopped
been a bad month for pc and laptop for me...
well i disconnected the quick disconnects in my system and see white stuff in my loop (no gold :)
removed pump cleaned etc, and it works again :) yay something good this time
But now i took everything out and want to do a proper cleaning, what do you guys use for your self?
wanna get all that white stuff that may be in rad the cpu block im gonna open up
i did not use dies cause i read horror stories, and obviously i have new feser tubing to put (old one looks fine actually)
tks in advance
https://linustechtips.com/topic/98160-best-way-to-clean-loop/
http://www.youtube.com/watch?v=AFhk5jZ4hbc&hd=1
Sorry I don't know much but I remember Linus vlogging about it during his Personal rig update.
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/98160-best-way-to-clean-loop/#findComment-1313153
I guess you could flush rad(s) with a 1:10 warm water and white vinegar solution. As for block(s), same water and vinegar solution with some toothbrush scrubbing.
CPU: Intel i7-3770k at 4.8Ghz  CPU Cooling: 320mm UT60  Motherboard: MSI Z77A-GD55  RAM: G.Skill Ripjaws X Series 16GB 2133Mhz (2x8GB)  SSD: Intel 330 Series 120GB  HDD: WD 1TB Caviar Green  GPU: EVGA GTX 780 x2  Sound Card: Creative Recon3D  PSU: Raidmax RX-1000AE 1000W  Case: Arc Midi R2  Monitor: Benq XL2420T at 129Hz  OS: W8 64Bit  Keyboard: Razer Blackwidow 2013 Ultimate  Mouse: Logitech MX518  Mousepad: Steelseries QCK+  Headset: Turtlebeach X12 (Temp.)
https://linustechtips.com/topic/98160-best-way-to-clean-loop/#findComment-1313158
White stuff? Step one is figuring out what it is and making sure it never ever ever gets back in your loop. :) To clean it all out the video by Linus posted above contains a couple of good tips.
its more like white flakes :)
pretty sure when i made my loop there was still regular water from flushing the rad...
oh ya im gonna scrub the hell out of the cpu block its impregnated with the white stuff, the tubing had it also but it just washed off
tks ill take a gander on the video
https://linustechtips.com/topic/98160-best-way-to-clean-loop/#findComment-1313202
This might be your white flakes...
http://www.overclock.net/t/1380775/what-is-plasticizer
https://linustechtips.com/topic/98160-best-way-to-clean-loop/#findComment-1317975
The white substance is plasticizer,use dish soap to remove.
Dont use vinegar for cleaning loops.
SR-2-2x X5650 Xeons-3x 670 FTW-1x 120Gb Force GT-1x 240Gb Force GT-1tb WD Green-12Gb Dom GT 1866-Platimax 1500w-2x HK3-2xD5-24v controller-3x RX 480's-3x NiBlk HK GPU blocks-Koolance tops-BP res-15x SP120's-Little Devil V8.
https://linustechtips.com/topic/98160-best-way-to-clean-loop/#findComment-1318504
White stuff is aluminium compounds. You most likely have copper and aluminium mix. I would suggest to get rid of all aluminium parts within the loop if it's too much white stuff (which it sounds like and the pump stopping.) Also use warm tap water and vinegar to clean, then just warm water twice, then pure H2O (distilled water without any minerals or so). Then mix 5:1 distilled water and car radiator fluid as your coolant. Car radiator fluid is the best.
Also use a D5 pump if possible. You have to literally kill them to make them die.
https://linustechtips.com/topic/98160-best-way-to-clean-loop/#findComment-1319910
Nope.
You find me a currently available block or rad made of Alu.
You cant.
Plasticizer is a well known problem, especially with primochill LRT pro.
Adding anti freeze will just sludge up. Please do research before posting.
https://linustechtips.com/topic/98160-best-way-to-clean-loop/#findComment-1320148
Nope.
You cant.
I am not talking about anti freeze or anti freeze coolant mixture. I'm talking about pure radiator coolant (The stuff without antifreeze can be found in Canadian Tire). BTW it's nice to know the plasticizer problem. I'm not using primochill LRT so never noticed that.
https://linustechtips.com/topic/98160-best-way-to-clean-loop/#findComment-1320700
no aluminum in my loop :)
i already have a swiftech mcp 350x and i like it i can make it run slow or high in wondows
 gotta take a pic already gor rid of tubing but it was not all white, the cpu block is still not all clean need to find hex key right size
https://linustechtips.com/topic/98160-best-way-to-clean-loop/#findComment-1321206
would kill coil not be enough?
https://linustechtips.com/topic/98160-best-way-to-clean-loop/#findComment-1321248
Nope.
You cant.
my tubing is tfc feser tubing, was well recomended when i bough it
https://linustechtips.com/topic/98160-best-way-to-clean-loop/#findComment-1321257
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/98160-best-way-to-clean-loop/#findComment-1321270
well i saw my feser tubing there :)
nice read, and long, worth it.
i got a laptop over a year ago and barely used the desktop, so it kinda just stood there....
https://linustechtips.com/topic/98160-best-way-to-clean-loop/#findComment-1321699
Nope.
You cant.
maximus vi formula is anodized aluminum
https://linustechtips.com/topic/98160-best-way-to-clean-loop/#findComment-1321950
yes i know it is treated but still that in my brand new system, water cooling is from my older system i, cleaning it to install in the new system on top of witch im having trouble getting distilled water, Walmart and no frills i went to was sold out... i still have to buy new tim tomorrow i hope
https://linustechtips.com/topic/98160-best-way-to-clean-loop/#findComment-1322441
     Well your problem sounds like organic gunk. Try kill coil. It would be better if you upload some photos. If it turns out to be organic stuff, iodine would be a great choice.
ya im wanna upload pics but its always out of focus my camara is at bros house, new years drinking left it there :) and i gotta buy a hex key to open the cpu block tks for the help guys
https://linustechtips.com/topic/98160-best-way-to-clean-loop/#findComment-1322460
was able to open cpu block used electric tooth brush, white stuff super easy, pic of the tube on the inside 2y and 6 months of use!
black part on cpu block inside seems harder to clear, already cleaned a bit
really sorry about pic quality i miss my canon and macro lens
post-52191-0-40740700-1389059980_thumb.j
post-52191-0-85278700-1389059987_thumb.j
post-52191-0-84428700-1389060013_thumb.j
https://linustechtips.com/topic/98160-best-way-to-clean-loop/#findComment-1322774
The key word is anodized.
Water cant penetrate therefore it wont corrode the Alu.
https://linustechtips.com/topic/98160-best-way-to-clean-loop/#findComment-1324441
