Here's a new one, I've never seen this before. Up until today, my sound card has worked perfectly, which is for about 6 months. Then, I discovered that during a skype call, the other person could hear me, but not the other way around. I then realised that I can't get any audio out from the back sound card at all. I've tried three sets of headphones and my surround speakers, and nothing works. However, using the front panel audio which connected to the sound, I get audio, even if it sounds worse.
The strange thing is that none of the rear jacks on the sound card work for outputting audio, but I can still use the purple one for my mic. Does anyone have any experience with how to fix this?
https://linustechtips.com/topic/98139-asus-ds-71-problems/
https://linustechtips.com/topic/98139-asus-ds-71-problems/#findComment-1312792
Try reinstalling modded drivers: http://maxedtech.com/asus-xonar-unified-drivers/
Personal Rig
i7 4790K | Asus Z97I-WiFi | CM 280L | Sapphire R9 290X Tri-X | Kingston ValueRAM 2 x 8GB | 128GB Samsung 840 Pro | 2TB Seagate SSHD | Seasonic Platinium 660W | Bitfenix Prodigy
https://linustechtips.com/topic/98139-asus-ds-71-problems/#findComment-1312799
you sure settings in windows are correct?
You sure the soundcard actually works anymore?( like the rear ports and shit) If you can install it in another machine and see there
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
https://linustechtips.com/topic/98139-asus-ds-71-problems/#findComment-1312822
I know that at least one of the rear ports works because I'm using it for the microphone, they just don't seem to work for audio out. This problem only started today
https://linustechtips.com/topic/98139-asus-ds-71-problems/#findComment-1312848
Skype does like to mess with your settings....
https://linustechtips.com/topic/98139-asus-ds-71-problems/#findComment-1312858
