Fix my pc please ...
Solved by roid,
roid - I'll start the blend test now but I'm pretty sure its not the RAM as I just brought the vengeance RAM. As far as temps go, the GPU temp never exceeds 80, and the CPU stays around 50
Did you transfer the drive with your OS from a different pc setup? If so you might have to do a fresh OS install like TideRower mentioned.
Temps seem normal though, do you have the latest nvidia drivers 331.82? How many sticks of vengeance RAM do you have 1 or 2 and at what frequency and clock speeds?
